NickParker
1. Can Miniature Circuit Breaker(MCB) be directly connected to the bus in the Low Voltage switch gear as per the IEC standard?
2. For Phase Indications of Incoming lines, (on the line side of the Incoming circuit breakers), should small control step down transformer be provided even if it has 3 phase 4 wire for low voltage. Why can't it be directly connected to the pilot lamps? for example, I have 3 phase 380 Volts with 4 wires which means I also have 220 V in it, So why can't I put the pilot lamps directly to the Incoming lines with fuse/MCB protection?
