No, you're out of luck. Piano wire, like music wire, is "patented" to produce a fine pearlitic structure. This involves quenching in a lead bath at around 800F.When you silver braze this material, you are re-austenitizing it and unless you have access to a lead bath, you will be unable to duplicate the cooling necessary to get the patented structure back. By water quenching, you are reverting to a martensitic structure and the end product would be more like a tempered wire product, not piano wire.
