A P&ID review should include representatives from process, piping, mechanical, instruments, electrical etc. The process that I like posts all P&ID's on a wall and walk each line showing the connections between each sheet, correct line numbers and specifications, equipment descriptions, etc. Discussion addresses startup and shutdown requirements for bypass lines etc. Some companies use a process hazard review as a PID review.
