tq3610
Geotechnical
- Mar 13, 2013
- 39
A question on the evaluation of pile capacity. In general, the pile size is calculated based on the vertical load capacity required. Then often an available lateral load on that pile is calculated and provided for design.
For a vertical pile, when checking the available capacity of the pile, would it be the correct process to check the combined vertical compression along with bending capacity (ie pile subject to compression and bending) if we are considering wind/seismic loads? Ie, if we have a battered pile that is taking vertical loads it is subject also to bending, so there is need to check combined compression/bending. Would it be typical to limit the compression or lateral capacity of the pile in the same way for a vertical pile subject to transient lateral loads?
