Pin Force 1
Creech
Hello
I'm trying to determine the minimum and maximum force that we can expect in lbs measured after we press a pin into a hole.
The pin is .0582/.0578 Dia x .1 long 420 SS ground finish
The hole is .0579/.0574. 17-4 stamped in .055/.053 thick material 50/50 shear to break
No lubrication.
Averag Poissons ratio for steel at .288 ?
Coefficient of friction .8 ?
E 30,000,000 ?
Our customer is looking for something like 50 lbs min but I need to find out how to calculate the min and max with the given tolerance stack. Any help would be greatly appreciated. - Rich
Hi Creech
Here are some formula that might help:-
Pa= f*3.142*d*L*Pc
where f=friction coefficient
Pc=contact pressure between the two members
d= nominal shaft dia
L=length of external member.
Pa= axial force required to interference fit
to calculate Pc for a given interference use the formula:-
Pc=x/[Dc*[((Dc^2+Di^2)/(Ei(Dc^2-Di^2))+....................
((Do^2+Dc^2)/(Eo*(Do^2-Dc^2))-((Ui/Ei)+
Ui/Eo))]
where x = total interference
Dc=dia of shaft
Di = dia of inner member(this is zero for solid shaft)
Do= outside dia of collar
Uo=poissons ratio for outer member
Ui=poissons ratio for inner member
Eo=modulus of elasticity for outer member
Ei=modulus of elasticity for inner member
This formula for Pc will simplify if the materials are the same.
Hope this helps
regards desertfox
Not to detract from desertfox's helpful reply which btw I starred but also:
Machinery's Handbook has an excellent article on press fit vs shrink-fit calcl's and resulting forces to remove pin.
Press fit is widely covered in all Mechanical Engineering and Machinist handbooks that I have read over the years.
Also, go no line and type "Press Fit"; All formulae on press fit are easy to apply.
