When integrating pin holes for tension eyebars or standard clevis connections what is the accepted tolerance for the hole placed in the structural. Further what is the tolerance on the roundness for the holes? AISC D6.2 states pin holes shall not be more than 1/32” larger than the pin, however, the code doesn’t appear to address the tolerance of the hole.
