Pinching of a solid sphere between two plates
CKJK
Chemical
Jul 26, 2020
24
I found something interested me from Abaqus documentation. It said this LCP solution is not supported in Abaqus/CAE. Does anyone have an idea how to simulate this kind of animation in Abaqus/CAE? I would like to give solid sphere density, viscosity, shear elasticity, and eos parameters, by the way.
Thanks in advance!
 https://files.engineering.com/getfile.aspx?folder=b9e204ae-ff49-4f5e-8259-caabf82124cd&file=Screenshot_(160).png
Indeed this technique is not supported by Abaqus/CAE. But you can activate it using the following keyword (either by editing the input file or using Keyword Editor): *Solution Technique, Type=LCP Contact
This contact method is for linear analysis. Your analysis will not be linear with the material options you plan to use, so you don't need that method. Just do a nonlinear analysis and use the regular contact options.
