Pinning to ledge / Doweling to bedrock
asabender
The engineers I trained under, and everyone in the area of New England we work in, pin foundations to ledge if in direct bearing... meaning #5 redar embedded 6" or so into crystalline bedrock at maybe 48" on center. I have done so for years, but was recently questioned about it, and realized (to my surprise) that I didn't know enough to give ready answers to specific design questions. I have designed more custom pinning/tendon anchorage to ledge using deep development and kwixset or epoxy for rock tendons, tensile anchors, tensile-shear dowels, and pure shear pinning; but only when I was working in non-standard applications. I tried researching it and came up empty. Does anyone have any thoughts on why this is a standard recommendation on a relatively flat site?
I provided an answer, so this is for my own elucidation. The answer I ended up giving was that it was basically for lateral restraint. Lateral restraint with pins/dowels being preferable since sites tend not to have flat interfaces between the stone and the concrete and the concrete leveling pads/footings tend to pop loose in temperature changes or under deformation. It's also a good idea to get some bite past the potentially cracked rock surface imho, and I correspondingly increase embedment to try to get into the sound crystalline stuff; but that was not included in my response.
That is not a standard detail I see in the southeast/midwest.
If the foundation is stable for sliding and overturning and the bedrock is sound, why put the dowels in?
If the dowels are needed for sliding or overturning stability I'd be going more than 6" with a #5.
