I need to use a seamless hot rolled pipe of material E235+N (1.0308) because that is what I found at the shop with the required dimensions. Here is a reference:
It is in the list of material of the standard EN 10305-4:2016 (Steel tubes for precision applications - Technical delivery conditions - Part 4: Seamless cold drawn tubes for hydraulic and pneumatic power systems) which referes to PED (there is annex ZA Annex ZA: Relationship between this European Standard and the Essential Requirements of Directive 2014/68/EU aimed to be covered). In this standard it is delivered only in the normalized heat treatment condition (+N) which is what I have also.
Also EN 10305-4 is in the PED list at:
E235 is also in other standards like EN 10297, but that is not even in the PED list. (any reason why the same material under a standard is in the PED list while not under another standard?)
The problem is that in these standards there is no table with the proof or yield strength at elevated temperature, so it seems useless for a PED application... (I do not see any logic for including such material and then not giving these values, so what is the purpose of this issue is beyond me). Can I use P235GH values instead ? They seem to be quite similar I suppose.
