Pipe Manufacturing / Material Grade
xnabrar
28
Hi All,
Anyone can explain the below material?
Material Grade = 1. HSAW/ X65
2. ERW/ X65
Thanks.
Sorry I crossed over. [blush]
“What I told you was true ... from a certain point of view.” - Obi-Wan Kenobi, "Return of the Jedi"
What happened to all the other posts?
xnabar - as said this is very simple stuff easily sourced from the internet.
HSAW Helical Submerged arc weld
ERW - Electric Resistance weld
The number after the X is the grade of pipe to API 5L
used to be ,000 psi SMYS, but now rounded to the nearest 5 MPa, so X 65 is 450 MPa,
I thought my comment was OK under the circumstances, but I guess it wasn't. So, I will simply no longer waste any time at all answering questions that a real engineer should be able to figure out for him or herself "." FULL STOP.
