sdz
- Dec 19, 2001
- 562
I have been asked to design /check a range of nozzle connections to water tanks, similar to the picture. This is a bolted corrugated water tank with ~2m head at the nozzle. Ideally the pipework is meant to be independently supported so the nozzle connection should not have to support significant pipe weight. Size is 150mm NB.
I think possible sources of loads could be static water pressure, flow loads, water hammer, someone standing on a fitting, ground movements (expansive soils).
So far I haven’t been able to find any recommendations appropriate to this sort of tank.
What we have here is a 150mm NB flanged fitting. A flat plate ~2mm thick is bolted to the inside of the tank with a loose flange on the inside. The tank has a liner so gaps between the flat plate and the corrugated wall don't matter.
