Mandrill22
I have a vertical schedule 80 PVC pipe, 6" diameter, 36" long with a male threaded NPT end. McMaster 4687T73. I'm trying to find a bell reducer to get it down to 2" or at least 4" so that I can put a cheap as possible valve on it (app below) Is there any reason I can't find one?
Alternatively, I could use the iron version of the pipe in the same size if that would reduce cost of the eventual valve.
Application:
The pipe is holding lead balls, total weight being up to 275 pounds.
Application:
