I'm trying to find some good material to learn more about pipe routing and supporting structures within a pipeline. For instance, if I have a large pump with a heavy filter after it, what's a "best practice" way to route the piping? How do I design a good support that gives maintenance access to the pump and filter? What are some common things I should consider in my pipe (e.g., strainer at the pump inlet, bypass around filter, etc.)?
Are there good online courses (set of DVDs, youtube videos, etc.) you'd recommend for this type of information? Or is there a good book or website that goes through some examples?
