pipe u/g crossing road backfill - flowable fill instead of soil
AskTooMuch
Petroleum
Jan 26, 2019
268
I have a pipe crossing a minor road so it went 4' u/g.
To backfill it's easier to use flowable fill because no compaction is necessary.
I want to ask if this is ok and will not affect pipe flexibility.
This is not a pipeline but a pipe mostly above ground and just went u/g for road crossing.
flowable fill isn't great normally because it creates a hard anchor point, but a 4" line?
shouldn't be an issue, just be careful how you compact and design the interface between flowable fill and normal fill to avoid a hard spot / edge.
Is this subject to thermal stresses or other movement?
The pipe isn't 4" (inches) diameter, the U/G depth is 4'(feet). The pipe is I is 12" diameter.
