I am installing some vacuum switchgear, and there is a little mix up in the pistol grip for the main breaker. We ordered the same grip as used in a previous job, which in the database said it had an interrupting current of 5A. However, when it got here it actually was only good for 3A. The VCB has a trip coil with a continuous current rating of 3A.
Is it alright to use a switch whos interrupting rating is equal to the continous trip coil rating? I usually buy a size up...
If not.. is it standard practice to use an interposing relay in the main trip circuit? Seems to me this would just be another piece of equipment that could malfunction between me and the trip coil?
