We have a problem, one of our compressor the piston rod was crack, it is suspected caused by condenseble material (ie. moisture / water content ). Can someone explain us What is the mechanism of piston rod cracking that caused by condenseble material ?, if true the cracking is caused by condenseble material, what is the condition or parameter that is able to this problem occur ?
