Dear All,
I have an issue of an impeller of the following specification:
- [highlight #8AE234]pump type:[/highlight] vertical mixed flow pump
- [highlight #8AE234]rotation speed:[/highlight] 355 rpm
- [highlight #8AE234]impeller:[/highlight] (Dia. 1485 mm) , Material: Gr.1 A CD-4MCu , Standard: ASTM A890
- [highlight #8AE234]Design Point[/highlight] (Flow : 30800m'/h, Head : 15.5m)
- [highlight #8AE234]Nature of fluid:[/highlight] SEA-WATER
- [highlight #8AE234]maximum Temperature:[/highlight] 33·c
- [highlight #8AE234]Available NPSH at pump impeller axis[/highlight] 12.65 mFG
- [highlight #8AE234]Required NPSH at pump impeller axis[/highlight] 7.2(3%)mFG
Finding
- Some irregular shape pitting in the blade in many location (pictures attached )
Questioning
- the reason of the pitting?
- what kind of corrosion or erosion happened?
- Could it be material and casting problem or long term mis-operation problem
Request:
- recommended repair procedure
Finding
Questioning
Request:
