Steel Inspector
- Jun 20, 2021
- 45
in beams, extra negative reinforcement at columns would be placed under the main upper reinforcement of the beam. in flat slabs however, the general practice ( at least in this part of the world ), is to place the extra negative reinforcement at columns over the slab top mesh. what happened in this case is that we would have to pour more concrete to provide concrete cover for the extra reinforcement steel. a very common example would be that we have an extra negative moment at columns consisting of a 20 mm diameter bar on both directions. if this extra steel is placed over the main slab top mesh, that means that we need to pour extra 4 cm of concrete to provide concrete cover for the extra steel. ofcourse this means an increase in slab thickness of 4 cm that is not accounted for during design. my question is. why not instead of that put the extra negative moment reinforcement under the top main mesh? just like in beams? wouldn't that be structurally correct?
