Hello All,
From Article :
Know Your pV Value
The pV value—the pressure (p) multiplied by the speed of operation (V)—measures the ability of the bearing material to accommodate the temperature limit generated by the
frictional energy during operation. The pV value alone is only one-half of what is needed to achieve a stable temperature limit. Therefore, the solution pV will be multiplied
by two for a design pV value before comparing with a material’s pV rating.
Why is pV value one-half of what is needed to achieve a stable temperature limit?
From Article :
Know Your pV Value
