If the process uses SMR as the front end, several areas need to be considered.
A. The two feeds have a different steam to carbon ratio and method of vaporization. Calculate the expected yields.
B. The by-product CO2 will be produced at a slightly reduced rate.
C. Depending on CO2 removal proces (PSA, Amine, Catacarb, or?)the loading will change.
D. Product Hydrogen should increase.
