HI,
I am looking at using a plastic molded can to house some electrial parts. It is going to be used in a hot and humid enviroment, about 60 - 70deg C. I have to make sure that the can can't leak or any moisture enter the can. The dim of teh can would be 170mm x 175mm x 275mm, the top of teh can will have a aluminium lid on it.
I was looking at ABS? or Polyethlene? I need it to be a molded part if possible?
