Plaxis
zxu
Geotechnical
Oct 28, 2003
1
Has anyone had any problems using the steady state groundwater module in Plaxis V8 ?? Does it work, or produce questionable results each time ?
Just been on an introductory course on Plaxis V8. It was mentioned that unless you put an interface around the plate (ie sheet pile)Plaxis would assume that the shhet pile was totally permeable and hence would just flow straight through it.
