Please help me to design this checking gage / fixture
pradeep_kumar
Automotive
Sep 20, 2018
1
Dear all,
I'm a gage designer with moderate experience. I was tasked to develop a gauge which needs to measure the 147mm from common axis of Datum A & B. The challenge to me was, the datum B is concentric 0.05mm with respect to datum A.
Since the diameters have very tight tolerance and this is a aluminum part, i must avoid damaging of the IDs.
Please help me to design this gauge. Thanks in advance.
 https://files.engineering.com/getfile.aspx?folder=93a7cb64-0bb5-451a-8c07-bba2d5968e63&file=Housing.PDF
pradeep kumar,
I see from your profile, you are new to Eng-Tips. Welcome.
You may have the wrong impression of Eng-Tips, this is a forum where engineers share experience, problems and solutions.
What you have asked for in your post was for someone to provide a design solution to your problem.
You will probably get a better response to your posting, if you first come up with a design solution, and provide what your requirements, limitations challenges are. Ask for advise on the feasibility of your design.
