Plot journal
rafl
PL
I’m working on the journal that will plot current drawing using plot profiles.
My code works only after entering PLOT menu, otherwise it gives an error.
Can someone help me fix this.
Code:
Imports NXOpen
Imports NXOpen.UF
Imports NXOpen.Drawings
Public Class Program
    ' class members
    Private Shared theSession As Session
    Private Shared theUI As UI = UI.GetUI
    Private Shared theUfSession As UFSession
    Private Shared lw As ListingWindow
    ' class methods
    Public Shared Function Main(ByVal args As String()) As Integer
        theSession = Session.GetSession()
        theUI = UI.GetUI()
        theUfSession = UFSession.GetUFSession()
        lw = theSession.ListingWindow
        'TODO: Add your application code here
        lw.Open()
        ' check for existing target work part
        Dim disp_part As Part = theSession.Parts.Display
        If disp_part Is Nothing Then
            lw.WriteLine("No displayed part...exit.")
            Return 1
        End If
        Dim sheetCollection As DrawingSheetCollection = disp_part.DrawingSheets
        Dim sheetArray As DrawingSheet() = sheetCollection.ToArray()
        Dim currentSheet As DrawingSheet = sheetCollection.CurrentDrawingSheet
        If currentSheet Is Nothing Then
            lw.WriteLine("No current drawing sheet found...exit." & vbLf)
            Return 1
        End If
        Dim noteText As String() = New String(2) {}
        Dim sheetNumber As Integer = 0
        For ii As Integer = 0 To sheetArray.Length - 1
            If currentSheet.Name = sheetArray(ii).Name Then
                sheetNumber = ii + 1
                Exit For
            End If
        Next
        Dim jobOpts As UFPlot.JobOptions = Nothing
        Dim bannerOpts As UFPlot.BannerOptions = Nothing
        Dim s As UFSession = UFSession.GetUFSession()
        Dim plot As UFPlot = s.Plot
        Dim ploter As String = "HP DJ 500 Ploter"
        Dim Profile As String = Nothing
        Dim ShSize As String
        ShSize = currentSheet.Length & "x" & currentSheet.Height
        ' lw.WriteLine(ShSize.ToString)
        If ShSize = "210x297" Then
            Profile = "A4"
        ElseIf ShSize = "420x297" Then
            Profile = "A3"
        ElseIf ShSize = "594x420" Then
            Profile = "A2"
        ElseIf ShSize = "841x594" Then
            Profile = "A1"
        ElseIf ShSize = "841x1189" Then
            Profile = "A0"
        End If
        plot.AskDefaultJobOptions(jobOpts)
        plot.AskDefaultBannerOptions(bannerOpts)
        Dim sheet As Tag
        s.Draw.AskCurrentDrawing(sheet)
        Dim JobName As String
        plot.AskDefaultJobName(sheet, JobName)
        plot.Print(sheet, jobOpts, JobName, bannerOpts, ploter, Profile, 1)
    End Function
    Public Shared Function GetUnloadOption(ByVal arg As String) As Integer
        'Unloads the image immediately after execution within NX
        Return System.Convert.ToInt32(Session.LibraryUnloadOption.Immediately)
    End Function
End Class
Yes, the ploter name is correct. In NX9 error says: "NXOpen.NXException: SDI Enviroment not setup" whereas NX8.5 error:"Invalid printer for plotting". Journal works only after I open and close PLOT menu.
