PLS-CADD and Memory
RMTower
I am working on a very large project file. I am exploring the different ways to reduce file size such as deleting points, filtering points etc. That's not what I'm wondering about. The 97% CPU usage (Sp?) memory warning I get specifically suggests, "Deactivating points and hiding attachments". When I try these methods it makes absolutely no difference to the file size. So why is it being suggested? What am I misunderstanding here?
Perhaps if those things are deactivated or hidden the program isn't pulling them into RAM. They are still part of the file, just aren't being accessed.
Right, even without these items activated I still get the same warnings about CPU usage. Must not be enough to make a difference to the requirements. Thank you.
