ShabsRBI
Materials
- May 3, 2023
- 36
There is a requirement to install a Control valve in Boiler Feed Water Service with a Operating Pressure of 4100 Kpa and temperature of 130 Deg C. The requirement is to have a Plug material with 316SS with COCr but the available valve has Plug material with 416SS. Similarly the Seat Material is also 416SS instead of Stellite6.
I looked at the Hardness of 416SS (40 HRC) and Stellite (44HRC), which are comparable. Temperature is also low. Boiler feed water is not a corrosive service.
Is it acceptable to have valve with 416SS components instead of SS316 COCr/Stellite6?
