Plugin with TreeList
mikechy
I created the plugin for Abaqus as an AFXList (Abaqus GUI Toolkit User's manual, Section 3.3.1 Lists) and it works (send selected item to main script). Now I want to create similar ones, but using FXTreeList (ibid., Section 3.5.1 Tree list) or AFXOptionTreeList (ibid., Section 3.5.1 Option tree list), however they do not pass a selected item.
So, I've created AFXList, which works properly, and FXTreeList and AFXOptionTreeList, which do not work:
1) Some code for AFXList from file *DB.py -
def __init__(self, form):
AFXDataDialog.__init__(self, form, 'Research',
self.OK|self.CANCEL, DIALOG_ACTIONS_SEPARATOR)
self.form = form
okBtn = self.getActionButton(self.ID_CLICKED_OK)
okBtn.setText('OK')
gb = FXGroupBox(self, 'MyLab', FRAME_GROOVE|LAYOUT_FILL_X)
hf = FXHorizontalFrame(gb, LAYOUT_FILL_X, 0,0,0,0, 0,0,0,0)
vf = FXVerticalFrame(hf, FRAME_SUNKEN|FRAME_THICK|LAYOUT_FILL_X,
0,0,0,0, 0,0,0,0)
List = AFXList(p=vf, nvis=5, tgt=form.mdlCodeKw, sel=0,
opts=HSCROLLING_OFF|LIST_SINGLESELECT|LAYOUT_FILL_X)
List.appendItem(text='Study_1')
List.appendItem(text='Research_2')
List.appendItem(text='Test_3')
List.appendItem(text='Case_4')
List.appendItem(text='Project_5')
2) Some code for FXTreeList -
self.form = form
okBtn.setText('OK')
0,0,0,0, 0,0,0,0)
self.tree = FXTreeList(vf, 15, form.MdlDistKw, 0,
TREELIST_SHOWS_BOXES|TREELIST_SHOWS_LINES|
TREELIST_ROOT_BOXES|
HSCROLLING_OFF|TREELIST_SINGLESELECT|LAYOUT_FILL_X)
option1 = self.tree.addItemLast(None, 'Numerical analysis')
self.tree.addItemLast(option1, 'Study_1')
self.tree.addItemLast(option1, 'Research_2')
option2 = self.tree.addItemLast(None, 'Laboratory tests')
self.tree.addItemLast(option2, 'Test_3')
self.tree.addItemLast(option2, 'Case_4')
option3 = self.tree.addItemLast(None, 'General publication')
option3a = self.tree.addItemLast(option3, 'Other researches')
self.tree.addItemLast(option3a, 'Ref-1_Project_5')
self.tree.expandTree(option1)
self.tree.expandTree(option2)
self.tree.expandTree(option3)
self.tree.expandTree(option3a)​
3) Code for AFXOptionTreeList -
self.form = form
okBtn.setText('OK')
0,0,0,0, 0,0,0,0)
tree = AFXOptionTreeList(vf, 10)
item = tree.addItemLast('Numerical_analysis')
item.addItemLast('Study_1')
item.addItemLast('Research_2')
item = tree.addItemLast('Laboratory tests')
item.addItemLast('Test_3')
item.addItemLast('Case_4')
item = tree.addItemLast('Other researches')
item.addItemLast('Ref-1_Project_5')​
The item selected in the list should be sent to the main code
I should clarify my question. The plugin creates a FXTreeList, for example, and after clicking OK creates a new model in Abaqus, but only with a default name 'MyMdl', regardless of which item in the tree is selected.
4) Code from *_plugin.py -
class TreeListEx_plugin(AFXForm):
def __init__(self, owner):
AFXForm.__init__(self, owner)
self.cmd = AFXGuiCommand(mode=self, method='createModel',
objectName='TreeListExCreate')
self.MdlDistKw = AFXStringKeyword(self.cmd, 'MdlDist', True, 'MyMdl')
def getFirstDialog(self):
import TreeListExDB
return TreeListExDB.TreeListExDB(self)​
In other words, item selection does not work. How to fix this? Thanks.
 https://files.engineering.com/getfile.aspx?folder=03201104-6bf6-436c-8256-6a09550340a3&file=tree.png
