PLYSWS Cable
veritas
467
I have come across a 6.35/11kV PLYSWS cable and would like to know what the PLYSWS stands for please. Cable is around 30 years old. Have not come across this before.
Thanks.
PLYSWS Paper Insulated Lead Alloy Sheathed Steel Wire Armoured and
Served (Cable)
Wow, that's a big thanks for that genhead. Could I push my luck a bit further and ask if you perhaps know where I can get info on the current carrying capability and impedances for a 3C 25mm2 Cu PLYSWS cable? As an approximation I am currently using a 25mm2 PILC cable with Z1 = 0.856 + j0.105 and Z0 = 1.3609 + j0.2672 ohms/km.
Thanks.
Sorry Veritas,
I don't know any technical details about the cable. I just remembered it from some old cable jointing instructions that I have from Australia. The drawing for the PLYSWS cable is from 1983 and was marked as obsolete back then.
Maybe Olex cables in Australia could help - they were around back then and still are now.
[URL unfurl="true"]https://res.cloudinary.com/engineering-com/image/upload/v1494991137/tips/PLYSWS_cable_jointing_i2mldq.pdf[/url]
No problem, thanks genhead.
Thanks for the cable info 7anoter4. Helps a great deal.
