BOPdesigner
NX 7.5: I just used PMI for the first time on three parts that I am making. I found it to be pretty straight forward, but my biggest concern is that I had to go through a lot of mouse clicks to get faces, etc, referenced or associated to the PMI dimension/note/callout. Is there a way that you can just click on a feature for example to associate that entire feature with a callout or dimension? Also, where are the ID symbol creation function and Insert Feature Parameters function in PMI, similar to what is in Drafting?
