Green 123
Aerospace
- Feb 19, 2024
- 37
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
much obligedIt has a piston and spring that push down on a ball. Air pressure down stream of the butterfly lifts the piston off the ball. The rate the piston moves is slowed by a needle valve. When the ball lifts it vents the actuator piston which closes the butterfly.
In short terms, it regulates the air pressure at the nozzle guide vanes.
