1
- #1
thalassic1
- Nov 23, 2013
- 1
Hello from someone just learning to use his new Sprite MYDIYCNC machine and Draftsight 2D.
I am needing help figuring out how to make what I call is a pocket. For example, I want to make a .500 in. circle become a countersunk hole, if you will, that I can place a round part into. I have no trouble
having Draftsight draw a circle and I have no trouble having the CNC cut a circle. The problem is getting the machine to cut out the entire hole, not just the outer edge of a pocket or hole if you will.
Any help would be appreciated. I have tried zplane and extrude, but to no avail. I think I must be doing something wrong.
Thank You,
thalassic 1
Thank You,
thalassic 1
