I am quoting from Aramco Standard...
When minimum wall tubes are specified, the tube-side pressure drop shall be based on 110% of the selected tube wall thickness. ??
Again...
Fixed tubesheet exchangers without the expansion joints are acceptable up to a maximum differential temperature of 28°C between tube mean metal temperature and average shell temperature.
What is meant by tube mean metal temperature Is it simply the skin / wall temperature?
Again...
