AMB DEC
- Jun 2, 2022
- 5
I am working on a project in which a homeowner would like to add a new polygon shaped window in the gable wall of the home. They will also be replacing the existing windows in kind. The roof is framed with scissor trusses @ 16" o.c. and the eave on the gable wall is 16". I am assuming 25 psf roof dead load and the roof snow load is 135 psf (320 plf total load to the header). I would like to present my concept for the design to the group to see if anyone has any feedback or advice with my approach (drawing attached). I plan to frame the polygon window with an arch style header and splice plate. I plan to use engineered lumber for the header to minimize any wood shrinkage and with screwing the plate to the header hope to prevent any slippage at the connection. The header will be supported at the ends with joist hangers into king studs. I am a little unclear with this splice plate design if there will be thrust at the ends of the header, but I have provided blocking/nailing in the shear wall to transfer this force from the header to the shear walls. My biggest unknown with this design is if the header will have any tendency to deflect and crack the window. Any input from the group is greatly appreciated and if I can provide further information to help address my question please let me know.
Thank you,
Austin
Thank you,
Austin
