Juanchoganda
- Jul 19, 2022
- 8
I have a project in Miami, FL where the client wants to add a roofed porch attached at the back of a residence? I'm thinking of adding 2x rafters with a wood beam and post to support it.
What kind of pressures should be used to to check the uplift on the structure? Should it be the roof or overhang pressure from the residence C&C values? or should I do a separate wind analysis using open structure values?
