I am using Autodesk Robot to model a standard low-pitch portal frame. In the software the rafters are modelled as two separate elements (broken by a central node at the apex).
There are separate settings for lateral buckling to define the spacing for adjoining members. However, I was wondering about the buckling along the major axis.
The rafter should be a full span element for the bucking along the major axis but it is split into two members and therefore the length is only L/2.
I can not make this super-member because it will change all the loading orientations in the model (as the rafters are not horizontal elements).
My understanding is that the buckling along the major axis is not really a problem because of small axial forces in the rafters. The most important is the lateral buckling along the weak axis restrained by adjoining purlins, stays etc.
Do you agree with me?
Karlos
