positive displacement fuel pump
mazen448
5
hello
is it must to use explosion proof motor with positive displacement (gear) pump
the application is fuel transfer
ul listed internal gear pump
is there any code explain thank you
You may check the Electrical Area Classification of the area where the electrical motor is to be used and verify the proper NEMA class and IP code for the motor as required to be used in that location.
