I am designing a nozzle to Figure UW-16.1(h).
The "lower fillet, New" box says the minimum sized weld can be 0mm. Shouldn't the minimum sized weld be tc as per the figure?
It works correctly for UW-16.1(s) where "lower fillet, New" minimum size is tw.
And it works correctly for when the shell and pad are both full pen where the "lower fillet, New" is optional and therefore as I understand it can be 0mm.
Is this a bug in compress?
