Does anyone have an idea why the below post-tensioning detail was added during construction?
We found the post-tensioning strands broken. However, it has been like this since 2017 and as far as I know not much has changed to the bridge. We are going out to take a look tomorrow.
Potential reasonings:
1. Someone found insufficient resistance in the column to resist lateral movement and detailed a quick fix during construction. Note: Bearing A has no lateral restraint capacity while Bearing B does.
2. Insufficient shear capacity at the edges of the column and therefore the need to install two new bearings.
3. Crack development during construction.
4. Transverse forces in the concrete deck.
