Pour Conrete
28
Hi all
How to create a model of concrete, it's just like pour concrete over deck pan & rebar
Thanks advance
Concrete is just going to be a solid model block. I would then create an assembly and insert your deck pan and rebar as required. You could probably do this as a multi-body part as well, but I think you might like the ability to have seperate models of your required rebar lengths and such.
I doubt you want to model the aggregate of the concrete.
MadMango
"Probable impossibilities are to be preferred to improbable possibilities."
Have you read faq731-376 to make the best use of Eng-Tips Forums?
Hi MadMango
thanks for your replied, my further question is can i get that solid model with deck pan & rebar shape extrudes
It sounds like you are looking for premade models. I am not sure of any sources that supply these types of models.
I always try to model items as they are manufactured. I don't think they make pre-stressed concrete forms with voids for inserting rebar and the like. Most concrete foundations are poured inplace.
MadMango
Not too sure where you are going with this, but if you seek a model of the aggregate only, say maybe for density calculations, make an assemby with the block of aggregate, deck pan, and rebar. Then edit the aggregate and Insert/Feature/Cavity and use the rebar to model the cavity. Do a separate cavity for the deck pan.
Crashj
