bhiggins
- Oct 15, 2016
- 152
Does anyone see any issues with pouring a concrete slab over a 138"L x 75"W x 59"D precast concrete grease trap tank. The concrete slab is a 7" dumpster pad slab and will be poured directly over the tank. The tank is rated for H20 loads. I'm thinking there should be a crack control joint surrounding the tank at the minimum. Should I detail an expansion joint surrounding the tank with a thickened slab at the edge or is this overkill? I'm thinking there may be some differential settlement of the tank and there should be some detailing to accommodate it, I'm not quite sure what is typical in this situation.
