Power Supply
prenavin
8
Hi there!
While going through my electronics cupboard, I came across a transformer rated at 32volts/ 3.22Amp (105VA). I would like to build a variable power supply with a current limiting feature using this transformer. Unfortunately, all the regulators I came across, has a maximum input voltage of 37 volts. The output voltage of the transformer, after smoothing will be 45.28V (32v x 1.414). Clearly this is not going to work. Could you advise me on possible solutions or circuits??? Also, is pulse width modulation an option to regulate the output voltage?
Hi, you could try a L296 switching regulator, I've used 1 for a bench power supply. You need to watch the input voltage as the 296 is rated at 46v and your transformer will give more than that off load. A descrete pre regulator, or a series zeneer diode. You will get 4A output but with an external pass transistor you can easily get 15A at 5v from it.
Linear Technology has about a dozen switchers that take more than that input voltage.
