Titirli123
Industrial
Dear Sirs,
I have start a pipeline project which is subject to ASME B31.1, so the PQRs should be done according to ASME Section IX.
Also, in the project is mentioned that it should comply with PED 2014/68/EU.
I discussed with an ASME Inspector and he told me that PED directive is requiring that I should do the impact test (in the project is nothing specified about impact test).
I am trying to make the PQRs and I have a few questions, if you are kindly to help me:
1. I have ISOS with A106 Gr. B (P no. 1, Group no. 1) and A106 Gr. C (P No. 1, Group no. 2)
From what I read in ASME Section IX it says that if you weld P no.1, Gr. no.1 with P no.1, Gr. no.2 your PQR will cover welding both materials and to each other.
2. I am confused also with the thickness range, for example for a pipe with thickness 168.3x14.27, the thickness range would be from 14.27 to 28.54?
I have attached a table with the welds of the projects and the PQRs that I intend to do. If someone can take a look and tell me if it's ok, I will be very grateful.
Thank you very much!
