Hi Structural Engineers
A developer(also a Contractor)want a building to be construct with a steel structural frame and pre stressed,pre-cast(PSPC)hollow core slab panels to be laid on top of the steel frame with a concrete topping to finish the building for a office.(pl. refer attached sketch)
My assignment is to carry out the design of the steel frame & to calculate the jacking force(how much PS force to apply)for a PSPC hollow core slab.
Steel framework design is straight forward. But since i am not much experienced in PS design work, I am having some points to get clarified. I can apply the Standard Pre-stress formulas to get the values of Prestress force & the eccentricity but I need the following facts also get cleared. ( As the sketch shows the maximum span of supporting beams to be 4.4 m ,design load is calculated as 12 KN/m2 and the maximum tensile stress of the chosen PS strand(7mm dia) to be 1670 N/mm2 & also the assumed section profile of the hollow core slab is shown in Fig:iii)
Questions:
1) Can I select the Concrete strength of PSPC slab as Grade 30 (30N/mm2)
2) Is it correct that I will calculate the jacking force by using the standard Pre-stress formulaes and add 20% for the losses and divide it by 6 (in this case)to find the jacking force of a single strand?
3) PSPC slabs will be laid on UB's with a simple connection.So I will assume the slab panels to be simply supported and will calculate the BM as for a Simply Supported beam. is it OK? do i need to provide a single strand at top level at close to the 2 side corners of the slab panel.
4)How do I provide PS strands for the cantilevered portion ( 1 m projection)? Do I need to provide PS strands at top and bottom of the panels which to be laid at the corner sections?
5)Can I optimize this PSPC hollow core section? What are the other facts do I need to consider.
