RPMG
- Nov 7, 2014
- 333
For a precast wall panel with vertical joints supporting a steel girder, should one assume a load distribution similar to a cast concrete/masonry wall or similar to a 8'-0" wide concrete column? In other words, is it better to use a uniform width wall footing or a spread footing below the girder?
