WelshEngineer87
Automotive
Hi all,
Does anyone know of any cast aluminum brackets that can have an aluminium insert pressed into them with an internal thread to tighten onto a fastener. This is for an extension to the bracket that cannot be accommodated by the casting
The press force of the insert would have to be higher than the tightening torque of the fastener to prevent slippage. Does this work if the internal thread of the insert is tightened to 28Nm?
