Hi All,
I'm designing a steam trap,
It's designed so that it satisfies both PED & ASME standards for min wall thickness etc
If I want to formally rate it to say, 600 PSI then as long as it passes the pressure test using pressure test equation for the material class that the end of it?
or is there a formal ASME Certified pathway to obtain a pressure rating to mark on the side of the trap, for example
cheers
cheers
