Metalmasterscm
I want to use a standard pressure regulator as the exhaust on a two and a half inch bore 5/8 rod standard pneumatic cylinder. I'm trying to figure out the pressure I would need to maintain 130 lb of pull tension on the rod. Basically if I want to pull on the rod and have a constant tension upon it as it's being extended and use the pressure regulator regulate the exhaust. If nothing else could someone supply me the formula to calculate it myself.
Thanks a lot gang!
Thanks a lot gang!
