I have been exploring addition of cooling baffle plates inside an existing pressure vessel. The addition of these plates would require new brackets to be welded to the sidewall of the vessel. We plan to do this in two parts - first, to weld the brackets on and put the vessel temporarily back into service while the rest of the installation is being prepared, and second, to weld in the baffle plates and associated cooling piping in the tank. Since welding the brackets to the vessel is touching the pressure boundary of the tank, I contacted an inspector to determine what would be needed for approval of the alteration. While I expected the required NDT for the bracket welds, what I did not expect was the inspector's assertion that ALL welds that then attach to those brackets then are also subject to the same requirement for inspection and approval. He seems to believe that anything attached to these brackets would now constitute a pressure boundary modification and would thus require inspection.
Where would he be getting this requirement? If I welded these brackets on and, say, later on welded on a vertical bracket riser on one of the already-installed brackets, how would that affect the pressure boundary of the vessel? The failure of that connection weld would not result in loss of containment.
Any guidance on what requirements are for this in ASME VIII? Any pointers on which subsections have definitions of the pressure boundary of the vessel and which sections cover alterations to existing vessels?
