skengg
- Jun 19, 2021
- 133
hello to all,
this is actually my first post in pressure vessel forum. i am actually a valves design engineer. our company wants to design a pressure vessel for safety valves testing(setting/adjusting desired pressure on steam flow). the pressure vessel will be connected to boiler through pipe line for regular steam supply. all i have data of Max. allowable working pressure(let's say 20 kg/cm2) and steam storage capacity(let's say 31000 kg/hr.) of pressure vessel.
i am newbie in pressure vessel design, can anybody of you recommend some literature or ASME section VIII specific code which i need to follow for vessel thickness design and other consideration. let me clear that it's only inhouse development for our safety valves testing so no need to focus much on ASME STAMPING and other standard consideration. all we need sustainable design which can hold pressure and fulfill our task.
