wydim
- May 29, 2018
- 40
Hello all,
I've got to quote the fabrication of a pressure vessel with a HALAR ECTFE coating.
According to coating manufacturer/installator, this coating is cured at 800°F.
I've read UG-99(k)(1) and (2) and I understand I can request an exemption (from the client) to perform an hydrotest prior to the coating and also exemption from leak test.
but what about the structural integrity of the welded joints and base metal at 800°F AFTER the curing at 800°F.
I don't need an PWHT (SA-240, ''thin'' material, 145 psig ), but what is the effect of this temperature on the atomic structure of the SS during operation of the tank. do I need special considerations for the calcs and design?
thank you !
thank you !
